Unilogic_Newbie Posted October 26, 2015 Report Share Posted October 26, 2015 Hi, I'm trying to move data table from SD card to USB memory stick. What is the default DOK file path? Quote Link to comment Share on other sites More sharing options...
s.pratt Posted October 26, 2015 Report Share Posted October 26, 2015 Hello, You must specify the folder path on the DOK. The exact folder paths for each folder directory are described on the help files in the "LF: SD File Functions" file. Hope this helps. Quote Link to comment Share on other sites More sharing options...
PBarrot Posted November 16, 2016 Report Share Posted November 16, 2016 Hello, I don't manage to use this fonction to move all files of the UserLogs/CSV/ directory to any place on a USB stick. Does the command "*.*" for the filename can be used ? (C/E of the copy/move fonction) What is the folder path in the DOK expected syntax ? For instance I have created a 'TEST' directory at the root of my disk : can I pass through #"TEST" as folder path ? (D of the copy/move fonction) Thanks you for any possible help to realise a simple fonction for user : "just one clic and get all your files copy on the USB stick". Regards, Patrice Barrot Quote Link to comment Share on other sites More sharing options...
