ervin Posted January 21, 2011 Report Share Posted January 21, 2011 I am using a V570 OPLC, which is working perfectly. I am saving all the alarms in the SD memory, as a requirement of the application I should be able to inspect or review the alarms. Does anyone knows how to open the Alarm file. In the pc I have the file with extension .UAL but I do not know how to open. Cheers, Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 21, 2011 Report Share Posted January 21, 2011 Yes, use SD Card Suite. It has a program called SD Card Manager... Quote Link to comment Share on other sites More sharing options...
