Joesteva Posted November 6, 2015 Report Share Posted November 6, 2015 Greettings, I'm a Electrical Engineer from Venezuela currently developing an application using one of your PLC, a USP-156-B Unistream device,I was testing the behavior of the data table and data trend funtionalities and when booted to implement in my project, the PLC requested an SD card, I inserted an 8Gb Sandisk micro SDHC SD card and proceeded to manually reboot (turning the power down, and then back up). Now the PLC won't get past the black screen with the UniStream logo (I believe this is the boot up function) with or without the SD card. Is there a way to upload the firmware? or how do I solve this? I can't get into Uniapps. Quote Link to comment Share on other sites More sharing options...
Ofir Posted November 11, 2015 Report Share Posted November 11, 2015 Hi Joesteva, Please send an Email to Support@unitronics.com as we wish to contact you directly about this case. Thanks! Quote Link to comment Share on other sites More sharing options...
Joesteva Posted December 18, 2015 Author Report Share Posted December 18, 2015 Thanks for the reply, the PLC had to be replaced by the manufacturer. It arrived two days ago, I'm currently working with the new one and everything is running perfectly. Quote Link to comment Share on other sites More sharing options...
jweav2223 Posted January 3, 2016 Report Share Posted January 3, 2016 I think I might be in a similar situation. I am attempting to load my first project to a UniStream 7" unit. I could never establish communication between unit and PC using supplied USB Cable. I set up a Network between the two devices and established communication, but UniLogic required me to update files on unit before it would allow me to upload my project. It asked for a USB Drive which I selected and it downloaded some files and provided directions to update. I went to UniApps and updated as directions said. Upload screen with warning to not disconnect power and not to remove USB Drive in multiple colors was flashing during process. Few minutes later was the "beep" noise of the restarting of the unit. Now will sit at the Unistream logo screen with flashing dash on top left hand side for multiple minutes before transferring to a blank screen. Quote Link to comment Share on other sites More sharing options...
Joesteva Posted January 7, 2016 Author Report Share Posted January 7, 2016 It is the exact behavior that I experienced, althought it was triggered by a different event. My solution was to replace the PLC (using the guarantee, I hope you can do that too). Quote Link to comment Share on other sites More sharing options...
