sunit Posted November 18, 2015 Report Share Posted November 18, 2015 A Samba 70 has a USB programming port and one optional port for Ethernet or RS232/485. I want to install a ethernet port but at the same time i want to use the USB programming port for MODBUS RTU to communicate with a remote IO by using a USB to RS485 converter, Is this posible? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 18, 2015 Report Share Posted November 18, 2015 Hi sunit, No, it is not possible. USB port is a Device port, not Host port. It does not support any types of converters. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted November 19, 2015 MVP 2023 Report Share Posted November 19, 2015 Samba Wall. Like the Jazz, the Samba should be thought of as a smart relay with a screen. Joe T. Quote Link to comment Share on other sites More sharing options...
sunit Posted November 20, 2015 Author Report Share Posted November 20, 2015 Hi sunit, No, it is not possible. USB port is a Device port, not Host port. It does not support any types of converters. Thank you sir Quote Link to comment Share on other sites More sharing options...
sunit Posted November 20, 2015 Author Report Share Posted November 20, 2015 Samba Wall. Like the Jazz, the Samba should be thought of as a smart relay with a screen. Joe T. Thank you sir Quote Link to comment Share on other sites More sharing options...
