mikecbmc Posted December 28, 2015 Report Share Posted December 28, 2015 I have a project with 45 motor drives that can use ethernet IP to control. I see the current limitation is 16 nodes, any thoughts on if this is going to be increased to say 100 or so Nodes? Quote Link to comment Share on other sites More sharing options...
Ofir Posted January 20, 2016 Report Share Posted January 20, 2016 Hi, Does the motor drives support Explicit messaging? or only implicit messaging? What is the maximum number of drives you are going to use? What is the speed you need to communicate with the drives? Please send also mail with this request to support@unitronics.com Thanks! Quote Link to comment Share on other sites More sharing options...
