cscheda Posted January 6, 2016 Report Share Posted January 6, 2016 Hello all, Does anyone have the example load cell example application that comes with the visilogic software? I do not have the install disc as I downloaded it from the Unitronics site. Thanks! Quote Link to comment Share on other sites More sharing options...
AlexUT Posted January 6, 2016 Report Share Posted January 6, 2016 Hi, After installation of VisiLogic/U90Ladder examples are installed as well. Open "Menu->Help->Examples" and look for one you need. You can convert V120 examples to any PLC model you have. I hope this helps. Quote Link to comment Share on other sites More sharing options...
cscheda Posted January 6, 2016 Author Report Share Posted January 6, 2016 Hi, After installation of VisiLogic/U90Ladder examples are installed as well. Open "Menu->Help->Examples" and look for one you need. You can convert V120 examples to any PLC model you have. I hope this helps. Thank you Alex. I did locate the example. Can you tell me how to convert the example to a V430? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted January 7, 2016 Report Share Posted January 7, 2016 Hi cscheda, Open "Menu->Project->Convert Project to Color->V430". Finish conversion. If selected PLC have the same IO assignment as source PLC - all IO assignment will be preserved. I hope this helps. B.R. Quote Link to comment Share on other sites More sharing options...
cscheda Posted January 7, 2016 Author Report Share Posted January 7, 2016 Once again, I thank you for your help. My application is up and running! Quote Link to comment Share on other sites More sharing options...
