MWD Posted January 21, 2016 Report Share Posted January 21, 2016 I wanted to make a accumulated hour meter. Seemed simple enough by just using the 1 sec pulse to trigger multiple count up accumulators, SEC, MIN, Hours. It appears that there is a limit for the number of function blocks that can be nested. In the attached example the first increment counter (sec) counts to 59 then resets MI20 to 0. The store command enables the second INC function M21 (MIN). This all works properly except for the last compare and store to reset the minute counter to 0. When the MI21 INC function ENO goes high, the compare block does not do the AB compare nor does the STORE function reset MI21 to 0. A trace does show the blocks are enabled but the function themselves do not work. Is there a limitation for the number of functions that can be chained? Theoretically I should be able to add another chain for hours. Other suggestions for a simple run time timer? Quote Link to comment Share on other sites More sharing options...
s.pratt Posted January 21, 2016 Report Share Posted January 21, 2016 Hello, Here is a cumulative timer example created that I know works for the mean time: http://forum.unitronics.com/index.php?/files/file/38-cumulating-timer/ As of now, i am unsure why the logic you have shown does not work, but I will try and test this logic. Hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted January 21, 2016 MVP 2023 Report Share Posted January 21, 2016 There is absolutely no reason to chain all that logic into a single ladder rung. This forum topic is "Best Programming Practices" and it should be noted that every bit of added complexity in a single ladder rung increases the chances that the compiled code will not be what you expected. In this case, it SHOULD all work, but why do it? Your example should be broken into 3 ladder rungs. Also note, you don't need SB1 (I find SB1 to be very useful to chain items in parallel, but you don't need it here when everything is in series), and MI20 is counting up to 6 seconds, not 60 seconds. Is that what you want? Quote Link to comment Share on other sites More sharing options...
MWD Posted January 21, 2016 Author Report Share Posted January 21, 2016 Thanks fellows, the example you attached is really the same as I was going to do in multiple rungs. I realize the ladder I wrote is not ideal, its just that sometimes I hack together a concept just to see how the blocks might work and then optimize after its understood. I ran into the problem submitted and was just wondering what the issue might be. Regards and thanks again for the input. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted January 25, 2016 Report Share Posted January 25, 2016 Thanks fellows, the example you attached is really the same as I was going to do in multiple rungs. I realize the ladder I wrote is not ideal, its just that sometimes I hack together a concept just to see how the blocks might work and then optimize after its understood. I ran into the problem submitted and was just wondering what the issue might be. Regards and thanks again for the input. Hello, After talking with colleagues in the office here, I understand now why this does not work and why we thought it would work: I was reading the statement you created as a "nested IF statement". But in reality, it is an "AND statement". Once the seconds register reach a value of '60', a value of '0' is stored into the seconds register, and makes the first compare statement not true anymore. So the minutes compare statement never gets evaluated. If you put the compare statements in parallel with eachother (making it an "OR statement") or place the second compare in the next net, the logic will work. Hope this helps. Quote Link to comment Share on other sites More sharing options...
MWD Posted January 26, 2016 Author Report Share Posted January 26, 2016 After pointing that out, that makes perfect sense. I wasn't thinking about it as an "and" string. Thanks for following up Shane. Quote Link to comment Share on other sites More sharing options...
