Kikis Posted January 22, 2016 Report Share Posted January 22, 2016 Hi guys, It would be great if we had a high speed analog I/O combined module with 16-bit resolution for Unistream. Conversion time should be 0.5mS or even less, if it's possible. There are applications where is crucial to have such an expansion module. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted January 27, 2016 Report Share Posted January 27, 2016 Hi :-) I have submitted your request--thanks! Quote Link to comment Share on other sites More sharing options...
cantcliff Posted February 11, 2016 Report Share Posted February 11, 2016 Hope this goes somewhere. Even is its not sub ms response time, 16 bit would be useful in general. 1 Quote Link to comment Share on other sites More sharing options...
Kikis Posted February 12, 2016 Author Report Share Posted February 12, 2016 In my applications (retrofits of injection molding machines) i need high resolution only for analog inputs. 12-bit analog output resolution is ok. However i also need much faster response time for both analog input and output than the existing modules. Quote Link to comment Share on other sites More sharing options...
Kikis Posted February 17, 2016 Author Report Share Posted February 17, 2016 Another needed feature is to have +10V power supply on the analog I/O module. This is to be used as reference voltage for linear position transducers. 10VDC power supplies are hard to find. So either i'am building it my self or if i have a free analog output i program it to continuously output 10V and use it as the reference for the pots. Quote Link to comment Share on other sites More sharing options...
