greml1n Posted February 9, 2016 Report Share Posted February 9, 2016 I am connecting to a Unistream remotely via ports 22 and 3335. I can successfully download and go online but cant write data tables. Unilogic says it cant connect to the remote device. Run discovery Quote Link to comment Share on other sites More sharing options...
greml1n Posted February 11, 2016 Author Report Share Posted February 11, 2016 Was able to load via recipe. Disregard Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 14, 2016 Report Share Posted February 14, 2016 Hi, don't disregard this. If something that supposed to work doesn't then we need to know about it, in order to fix it. I understand that you connect to the PLC using Ethernet, but when you try to write offline (predefined) values to the PLC, it give you an error. Am I correct? Quote Link to comment Share on other sites More sharing options...
greml1n Posted February 14, 2016 Author Report Share Posted February 14, 2016 Correct. I could download the program and go online but when I tried to write the data tables it wouldn't connect Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 16, 2016 Report Share Posted February 16, 2016 Does it always happen with this project? What happens if you reboot your PLC (If you can), does it solve the problem? Quote Link to comment Share on other sites More sharing options...
greml1n Posted February 17, 2016 Author Report Share Posted February 17, 2016 It was the first time I tried writing data tables over the internet. Quote Link to comment Share on other sites More sharing options...
