Hamza1 Posted February 17, 2016 Report Share Posted February 17, 2016 Hello i have problem with communication RS232 i us PLC v1210 i need communicate with 10 different device problem that i cant receive message from all all time i receive from device number 1. 3. 5. 7. 9 i dont know where is the problem ? Quote Link to comment Share on other sites More sharing options...
cantcliff Posted February 18, 2016 Report Share Posted February 18, 2016 RS-232 is a point-to-point protocol. You can't have multiple devices on an RS-232 connection without some very clever work arounds. You want to use RS-485 for multiple devices as it's designed for it. Quote Link to comment Share on other sites More sharing options...
Hamza1 Posted February 18, 2016 Author Report Share Posted February 18, 2016 hi cantcliff i cant us RS-485 because my devices dont have this option Quote Link to comment Share on other sites More sharing options...
s.pratt Posted February 18, 2016 Report Share Posted February 18, 2016 hi cantcliff i cant us RS-485 because my devices dont have this option What other communication lines does your end devices support? Can you add RS323 to RS485 converters? As cantcliff has stated, RS232 is point-to-point only - there is no way to address multiple nodes. You will need some sort of third party device to communicate to multiple devices with RS232, such as an RS232 to RS485 converter. Quote Link to comment Share on other sites More sharing options...
Hamza1 Posted February 18, 2016 Author Report Share Posted February 18, 2016 thank you acsely i found solution for may problem i change seting of can initialize ( baud rate) i go form 57600 to 38400 . now i receive messege from all devices if some one want see my programme i dont have problem to send Quote Link to comment Share on other sites More sharing options...
cantcliff Posted February 19, 2016 Report Share Posted February 19, 2016 Just a warning, you may get un-intended communication issues sticking with RS-232. It can work as multi-tap but was never intended. Make sure you have sufficient sanity checks in your program to prevent process problems from bad communication. Quote Link to comment Share on other sites More sharing options...
