pgold50 Posted March 1, 2016 Report Share Posted March 1, 2016 hi all, so i have this trouble regarding an application that uses a v120 and enfora modem. the plc receives messages no problem with it. what we encounter is that when i use a different sim card for sending an sms to the plc, it receives the message but the phone number is displayed as+0918******* and not as +63918******* which has the country code. this results in me not being able to trigger the receive bit in the plc. i can change the number to +0918*******, to command but the problem is that the plc won't be able to reply to the said number. has anone else experienced this? i can use the same network and the phone number has the country code, but a different network doesn,t Quote Link to comment Share on other sites More sharing options...
