max_145 Posted March 2, 2016 Report Share Posted March 2, 2016 Dear support team, is ther a way to use an shaft encoder that uses SSI protocol (RS485 interface) with UniStream? Thanks BR Quote Link to comment Share on other sites More sharing options...
s.pratt Posted March 2, 2016 Report Share Posted March 2, 2016 Hello, Does you device have a specification sheet that explains the protocol layout of the SSI protocol? We do not directly support this protocol, but we may be able to program it. If you can interpret this protocol, we may be able to program the UniStream to work with this encoder. We can move the RS485 buffer to a buffer tag dependent on three conditions - amount of bytes received, a time frame, or an end of text character. Please let us know and we would be happy to assist. Quote Link to comment Share on other sites More sharing options...
max_145 Posted March 3, 2016 Author Report Share Posted March 3, 2016 Hi, many thanks for the fast reply. I think I will use a CanOpen device instead. Maybe UniStream supports SSI in future, because SSi devices are much cheaper. Thanks and BR Quote Link to comment Share on other sites More sharing options...
Stwolos Posted January 18, 2019 Report Share Posted January 18, 2019 Hey, I know that I'm worming up old meat, but this is also a case for me. I have been planning to use SSI over RS485 (use one signal as a clock second as a input) but I don't think that there is a tool for doing this in vision. I have V430-J-B1 PLC. Attached you can find SSI protocol descr. Do you think it is possible to comunicate it with V430 PLC? SSI-opis.pdf Quote Link to comment Share on other sites More sharing options...
DanT Posted January 18, 2019 Report Share Posted January 18, 2019 HI; SSI is not supported. Look at a CanOpen device. You will need to install the V100-17-CAN Module for CANO Dan Quote Link to comment Share on other sites More sharing options...
