prairiecreek Posted March 8, 2016 Report Share Posted March 8, 2016 I am updating a project with an NPN hall effect sensor. I am wondering exactly how to wire it properly to the i/o card. The sensor has 3 wires, voltage +, voltage - and signal out. I'll have to install it on the bank of digital inputs 10-18 as these are currently unused. I am using the v200-18-e5b snap in module. Your help is greatly appreciated. thanks guys. btw, I am using this as a pulse reference for a timer to determine if the part is moving and if not, it will shut down after a predetermined length of time. If it is important, the rpm is 30 with 8 pulses per revolution yielding 4 pulses per second. The sensor in question is the model 906 from electro-sensors.com thanks again. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 8, 2016 Report Share Posted March 8, 2016 Hi, As soon as this hall sensor is rated for 5-24 V and have NPN open-collector output, and it is rated for 50 mA, it will be used as source of digital signal for digital input. Use npn (sink) high-speed counter configuration. Quote Link to comment Share on other sites More sharing options...
prairiecreek Posted March 8, 2016 Author Report Share Posted March 8, 2016 thank you uniguru but I have just one clarification needed. If I use the same power positive and negative as my power supply for the sensor, which is 24v rated btw, can I just send the signal line to the digital input of my choosing? Of course, I know to setup the hardware to expect the signal on say line input 12. could you possibly draw the schematic as you would wire it? Thanks again. Quote Link to comment Share on other sites More sharing options...
