etalon Posted March 10, 2016 Report Share Posted March 10, 2016 Hello, I have a project that has reliability issues that seem to stem from the PLC losing connection to its router on socket 20256. On a PLC where the connection is lost: If I ask the router to do a standard ping against the router, it succeeds. If I ask the router to do a TCP socket ping with 20256, it fails. (on a PLC I am successfully getting data from, this succeeds) The kludgy way I am temporarily getting round this, is the router is set to do a hard reset every 4 hours which reinitialises everything Bit of background: Remote server using unicomdriv.dll is communicating via VPN over a GSM modem to the PLC over Ethernet (sounds dodgier than it actually is!). I have a screenshot of the bits of code that manage the connection on the PLC code, what I am thinking is I need something to detect a situation of the PLC losing connection or no successful data transfer over socket 1, and initiate a sequence to regain the connection. Any suggestions? Any suggestions of parameter settings for timeout and keepalive ect... on the PLC itself? Roy Quote Link to comment Share on other sites More sharing options...
