cscheda Posted March 11, 2016 Report Share Posted March 11, 2016 Hi All, I am using a V430-J-TA24, Hardware rev B, OS 4.0 (19) with Visilogic VER 9.9.2 build 0. My issue for today is that the ascii key pad entry screen appears, but it is not centered in the screen. It is centered too far to the right and as a result, the screen wraps around and continues on the left hand side of the display. If I could shift the whole screen to the left, it would fix the issue. I know there is an x and y setting SI 245 and 246, but it says this is for the 1020 model.... Any suggestions on how to correct this? Thanks once again Quote Link to comment Share on other sites More sharing options...
cscheda Posted March 14, 2016 Author Report Share Posted March 14, 2016 Any thoughts? Quote Link to comment Share on other sites More sharing options...
cscheda Posted March 15, 2016 Author Report Share Posted March 15, 2016 Just an FYI...... I had to upgrade the OS for the controller and that was the correct fix. Quote Link to comment Share on other sites More sharing options...
