Convert number to string
dulu
  • 1 year later...
Hello,
I have problem with UDFB called Num to ASCII.ulle. I use it in my project, where i need convert number to ASCII and padding with zeroes.  The convert number to ASCII work well but the padding does not function correctly, when i configure padding (2) the function shoult return me some number and padding with zeroes but still fill place with space. I donť know where is problem.
Can you help me?
Thank you.
  • 3 weeks later...
