nettron2 Posted March 21, 2016 Report Share Posted March 21, 2016 Hi All I'm Using V130. Use Shaft Encoder Input As Feedback For My Application. The Issue Is The Value From The Encoder Not Able To Be Keep Permanently means that when i power off (V130 Supply) & ON back, the value will be zero. Can Anyone help. How To Keep The Value As Before power Off. Tq Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted March 21, 2016 MVP 2023 Report Share Posted March 21, 2016 Use Store Direct to copy that value to a temporary location on every PLC scan. Then use SB2 to copy the value back on startup. 1 Quote Link to comment Share on other sites More sharing options...
