simba Posted March 26, 2016 Report Share Posted March 26, 2016 am working on a program that dispenses fluids from tanks using a pump in various quantities for various costs. need assist in the code that will allow when i key in an amount the pump out a quantity that is proportional to the amount. please assist Quote Link to comment Share on other sites More sharing options...
Walkerok Posted March 28, 2016 Report Share Posted March 28, 2016 It is not possible for anyone to help with your question without knowing what the mechanical components are and how they work. Just an example question ......................... what pumps the fluid? Depending on the answer you have remarkable different solutions to the problem. Just an assumption but a vending machine that needs to meter out a fluid generally will be using a "systolic pump" so for each rotation of the pump a fixed quantity of fluid is dispensed, but non one can guess how fast the rotations will be or how much the pump dispenses in volume per rotation. You have to be much more specific in what you are using and what you are doing. good luck Keith Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 29, 2016 MVP 2023 Report Share Posted March 29, 2016 Better yet, post your code. Joe T. Quote Link to comment Share on other sites More sharing options...
