Don2015 Posted March 28, 2016 Report Share Posted March 28, 2016 Ok, I have done this before on a different PLC brand, but then again the different PLC brand did not have HMI built into the PLC. By using inputs, and device net addresses, I was able to automatically load a different program into the PLC from the SD card, when a jig was connected fixture. So each program had it's own loading program within it. Will I be able to do this with a V700, and if so how many .vlp files could I have on an 8GB SD card? Thanks, Don Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 29, 2016 MVP 2023 Report Share Posted March 29, 2016 Look at the "SD Clone" function under the SD menu. You'll need to figure out a method to determine which file gets loaded. Joe T. Quote Link to comment Share on other sites More sharing options...
