andrew39 Posted March 31, 2016 Report Share Posted March 31, 2016 Hello. I am bassicaly new at this forum and also at Unitronics PLCs. However i got assigment to solve a problem with Unistronics PLC V1210. At start screen PLC is showing message - No Application and I need to remove this message and upload old program. I read at forum about it and its probably because power failure or battery is running low. I tried to download program to PLC via ethernet cable and i got this message (Capture). How to setup communication and download program to PLC? And when I succesfully download and burn program to PLC this message no aplication will dissapear? I have attached images to this post below. Best regards, Andrew. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted March 31, 2016 MVP 2023 Report Share Posted March 31, 2016 The easiest thing to do is to use a serial or USB cable to download the program. If you don't have that available and must download using ethernet, do the following: 1) Confirm that PLC and PC are on the same subnet (192.168.192.xxx, in your photo). Change one or the other to match. 2) Identify the PLC Name. Go to INFO Mode / Version / Software / PLC Name 3) Enter the correct PLC IP address and PLC name in the VisiLogic - Connection / Communication - PC Settings / Select Connection Type - TCP/IP (Call), then Project Settings. Test connection by clicking on Get OPLC Information. I recommend checking and/or replacing the battery immediately to avoid having to repeat all this. You can check the battery by going online with the PLC and looking at the value of SB8. A value of 1 means the battery needs replacing. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
andrew39 Posted April 11, 2016 Author Report Share Posted April 11, 2016 Hello again and thanks for answer. I tried to download with ethernet but same problem. However i acquired USB cable and now im trying to download program but i get error. Invalide procedure call or argument. How to solve this, install USB driver and download program succesfully to PLC with USB cable? Best regards, Andrew. Quote Link to comment Share on other sites More sharing options...
