Martin Holaň Posted April 19, 2016 Report Share Posted April 19, 2016 Hi, I have a problem in visilogic with Runtime. After start program, popout first "Run-Time error 438. Object doesnt support this property or method." After start program shows second window with "Run-Time error -2147418105 (80010007). Automation Error." Then program close. I tried reinstal software, deleted all folders Unitronics (program files, program common). Not works. This error start on old version 8.7, then I try update on last version...same problem. I have Win7 Pro 64bit, SP1 Thanks for suggestions. Quote Link to comment Share on other sites More sharing options...
Martin Holaň Posted April 20, 2016 Author Report Share Posted April 20, 2016 I answer myself. Quick solution, works for me: Instal last version of Visilogic on PC with Windows 10. Copy all files from folders C:\Program Files (x86)\Unitronics and C:\Program Files (x86)\Common Files\Unitronics Insert into same folder in pc with runtime error, replace all. Done, problem solved. Quote Link to comment Share on other sites More sharing options...
DaveE Posted April 21, 2016 Report Share Posted April 21, 2016 I had the same issue I just set to run as admin in compatibility mode.. went away Dave Quote Link to comment Share on other sites More sharing options...
