KristienP Posted April 30, 2016 Report Share Posted April 30, 2016 I'm developing SCADA graphics, and was just supplied with an address list from the PLC programmer. After looking over manuals/webinars/forum posts I'm looking to get some verification on whether I got the Modbus addressing correct or not. This is my first experience having to interface with an Unitronics PLC... I'm used to AB or SCADAPacks mostly... Quote Link to comment Share on other sites More sharing options...
renato.pierri Posted July 3, 2016 Report Share Posted July 3, 2016 Hi. Take a look at this website -> http://nets-nuts.com.br/pt/industria/vision-v350-indusoft-modbus/ That site has a table relating Indusoft I/O addresses to Vision V350 registers enabling you to easily connect each other. I have done that table checking the Indusoft driver documentation and the the Visilogic Function Blocks V230-21-G23 Rev: 3:00 manual. Last three links in the page have following sample projects for download (as is): -> V350 Modbus slave using serial port -> V350 ModbusIP slave using Ethernet interface -> Indusoft project using MOTCP drivers (Modbus IP) Hope it helps and please, let me know if that worked for you and if I need to improve something. Quote Link to comment Share on other sites More sharing options...
