MVP 2023 Joe Tauser Posted May 2, 2016 MVP 2023 Report Share Posted May 2, 2016 I just finished a project with four languages in four string libraries. The most frustrating problem I ran into was when I needed a word or phrase I had already set up to be a different size font for use on a different display. I tried the "copy to all libraries" function, but all that did was copy the same English word to Spanish, French, and German. This is not useful. My workaround was to select each library and then copy the entry from one place to another, and then select the next library and repeat the process. Am I missing something? This was a royal pain in the butt. It would be logical to copy all members of the library at once. Then I could modify the font properties in the new entry. Joe T. Quote Link to comment Share on other sites More sharing options...
