Hamza1 Posted May 2, 2016 Report Share Posted May 2, 2016 heloo i have problem with calculed BC= AB x sin a i need resulta in degrees i have plc V700 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted May 2, 2016 Report Share Posted May 2, 2016 Hi, Google say: 1 Radian = 57.2958 Degree. Then 0.017453 Radian = 0.9999832398418258 Degree (~1 Degree). Use this in your formula. B.R. Quote Link to comment Share on other sites More sharing options...
Hamza1 Posted May 3, 2016 Author Report Share Posted May 3, 2016 hi alex thank you for your unswer but i cant use this because same time i have result in minus Quote Link to comment Share on other sites More sharing options...
cantcliff Posted May 3, 2016 Report Share Posted May 3, 2016 I'm confused by your formula. Something doesn't make sense to me without knowing the application. Are you trying to find angle (a) or BC? Quote Link to comment Share on other sites More sharing options...
DaveE Posted May 5, 2016 Report Share Posted May 5, 2016 I am confused too It appears from what you are saying that you want to know the Angle a the calculation for the SIN of an angle is Sin(a) = Opposite/Adjacent (It appears to me that you know Opposite (BC) and you know Adjacent (AB) So: From what you have written you simply divide BC/AB and you will get the Sin(a) result If I am correct in my assumptions (probably not) then you know the Opposite and Adjacent Better off using this cot(a) = Adjacent / Opposite which is Cot(a) = AB/BC However thats all a complete guess as we dont know what you are doing here Just one thing if you use MI's then you will not be correct in your calculations (they can only hold whole numbers) (OMG school boy math) Quote Link to comment Share on other sites More sharing options...
Hamza1 Posted May 7, 2016 Author Report Share Posted May 7, 2016 i trying to find angle BC Quote Link to comment Share on other sites More sharing options...
DaveE Posted May 11, 2016 Report Share Posted May 11, 2016 Ok. Now tell us what you are doing Where is your info coming from Post your code? Quote Link to comment Share on other sites More sharing options...
cantcliff Posted May 17, 2016 Report Share Posted May 17, 2016 i trying to find angle BC Are you using the law of sines? https://en.wikipedia.org/wiki/Law_of_sines From what I vaguely remember if you get a negative result, the angle is still valid, however if means you're moving in the opposite direction around the unit circle. To convert to a positive angle, simply add 360 to it. However, you're using a non-standard notation for me, so I'm not sure if you're using the correct numbers, angles and side length, in your equation to spit out good numbers. Typically, angles are represented with capital letters, and the side opposite the angle is a lower case. See wiki link above, or post an image of your triangle with everything labeled. Quote Link to comment Share on other sites More sharing options...
