Nildo Posted June 2, 2016 Report Share Posted June 2, 2016 Hi friends,i have an counter that it have been fail in count of our machine through signal pulse of encoder. i want to use it (v1210) for measure the number of product that go out of machine of press. I need of values of: liquid counter gross counter reset both and accumulated Anybody have idea about this application then please learn me. Best regards, Nildo Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 4, 2016 MVP 2023 Report Share Posted June 4, 2016 Label your diagram better. Where are the liquid and gross counter pulses coming from? Joe T. Quote Link to comment Share on other sites More sharing options...
Nildo Posted June 4, 2016 Author Report Share Posted June 4, 2016 All value comes from k1(encoder) gross counter.and i believe liquid is formule. How to use a counter with HSC for this application? Tk you. Nildo Quote Link to comment Share on other sites More sharing options...
Nildo Posted June 4, 2016 Author Report Share Posted June 4, 2016 Hi Joe, All sign pulse come to pin k1 (B70-encoder). One go to S7-300 and other go to convertor frequency (1:2) that go to input cartoon. I believe that CPU need only of a pulse of reference to obtain gross counter. And for calculate result value of count liquid. Please check more detail in your personal email. Thank you for now. Nildo Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 5, 2016 MVP 2023 Report Share Posted June 5, 2016 Nildo- So it looks like A70 is some kind of scaling module configured by which input pins are tied to +24V. Thanks for the clarification on K1. You have to tell your doctor these things. I'll check my email tomorrow, but for purposes of the forum which I/O module are you using? To get a HSC on a V1210 you'll need a snap IO module (one of the V200s). Joe T. Quote Link to comment Share on other sites More sharing options...
Nildo Posted June 5, 2016 Author Report Share Posted June 5, 2016 Thank you for answer Joe. I am using right now a [V1210]+[v200-18-ex3xb] for test of read value direct of counter(Sensor 5 pin Visolux LT63/70b). Fist step is read value correct of counter. But in future I will use [V1210]+[v200-18-ex3xb] connected network Canbus with [EX-RC1]+[iO-DI8-TO8]. Email again. Meus cumprimentos, Nildo Quote Link to comment Share on other sites More sharing options...
Nildo Posted June 7, 2016 Author Report Share Posted June 7, 2016 Hi Joe, please when possible return me. Thank you for now Nildo Quote Link to comment Share on other sites More sharing options...
