kwesonga Posted July 4, 2016 Report Share Posted July 4, 2016 I have a V570 with I/O extensions IO-DI8-RO8 AND IO-AI4-AO2 I have done the configuration and downloaded the program,everything looks fine on the hardware side,however when i activate an input with 24v,the input LED goes on but when i go online the Input Bit does not go ON hence the program cant see the input what could be the issue Kenedy Quote Link to comment Share on other sites More sharing options...
s.pratt Posted July 5, 2016 Report Share Posted July 5, 2016 Hello Kenedy, Which physical input are you using on the I/O module? Which software input are you minitoring? Quote Link to comment Share on other sites More sharing options...
