Splathappy Posted July 7, 2016 Report Share Posted July 7, 2016 Does anyone have experience with interfacing IO-Link into UniLogic? I have only done some basic programming and have no idea were to begin with IO-Link. it will be used with process instruments and SMC solenoid valves. Quote Link to comment Share on other sites More sharing options...
Malcolm Posted February 15, 2017 Report Share Posted February 15, 2017 Hi Splathappy, IO Link is an extension to existing protocols. You could use an EthernetIP Field coupler that speaks IO Link to make it work.AXL E EIP IOL8 DI4 M12 6P From Phoenix Contact can make this happen for you. BTW IO Link is definitely something great to look at! Best Regards, 1 Quote Link to comment Share on other sites More sharing options...
