Hi all,
at the moment i am using a Vision350 Controller for a small machine type.
We think about replacing the Vison350 with the new 7 Inch samba.
Now i have a few questions, because i am not sure if the memory of the samba would be enough for this program.
* How can i find out the memory used in the Vision350 controller?
  I already looked at the "project memory map", but i did not get really useful information from there.
  I only see that i am using 4,9 % of the DLU capacity, but i do not find any information about how many kb are used for ladder code, hmi variables, ..........
* Is there any way to export my code from the Vison350 and reimport it in Samba?
  I already tried to change the hardware in the project, but it is not possible to keep the hmi screens and the ladder code.....
  I also tried to export the ladder subroutines one by one, but also here the import is not possible, because i always get the message that some used operands are not available on the samba platform.
  Of course i have to re-adress some variables, but it is just not possible if i cannot import the subroutine in my samba project.
Any tips would be helpful, as i think that this small project would fit in the Samba models. And using a 7 Inch display would be better than the 3,5 inch from the Vision.
Thanks
BR
  • 1 month later...
  • MVP 2023
Move those operand addresses FIRST before exporting.
  • Upvote 2
On 15/7/2016 at 5:06 AM, max_145 said:
Hi all,
Thanks
BR
As Flex told you, use the FIND AND REPLACE command to move the variables so they can fit in the available space in Samba. I made the switch from V350 to Samba for small machines and is working ok. I don´t know how to measure the space a program requires but I never get out of memory with Unitronics.
Good luck
  • MVP 2023
1 hour ago, HigHTech said:
...but I never get out of memory with Unitronics.
I totally agree with HigHTech, but I have found that if you have more than 4 or 5 screens on the Samba, you will have a big problem with memory. This is especially true if they are even moderately complex screens with a number of elements on each. I suspect that will be your number one problem with memory limitation when you move from the V350 to the Samba.
This project has 4 screens with a lot of variables (more than 63 HMI) and you can see I have like 40% free. So I think Samba can handle 10 screens and lets say 160 variables.
I am very sure that before you run out of memory you run out of I/O´s. So that´s must of the time my check point.
