SolidRO Posted July 19, 2016 Report Share Posted July 19, 2016 Hello, I am interested in finding a way to put indirect values/operands on a Dial Graph's ranges. By doing so i can modify the redzone of an odometer. Thank you. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted July 21, 2016 MVP 2023 Report Share Posted July 21, 2016 Unfortunately that is not an option with the current revision of Visilogic. Creator input? Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 21, 2016 MVP 2023 Report Share Posted July 21, 2016 If there are not too many different ranges possible, just create a separate screen for each and the appropriate logic. 1 Quote Link to comment Share on other sites More sharing options...
