shh Posted July 27, 2016 Report Share Posted July 27, 2016 Does anybody know why this is showing up?. This is the new trend after I got the latest version of Vicilogic (9.8.31). Best regards. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 27, 2016 MVP 2023 Report Share Posted July 27, 2016 Have you tried downloading a blank project first, then downloading your project? I've found that sometimes a PLC needs to be "cleared out" after downloading multiple projects (or even the same project multiple times during program development). Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted July 28, 2016 Report Share Posted July 28, 2016 I've got the same error several times with current project development including several images. I had to close Visilogic, re-open it and download again. It forces PLC to download entire images set instead of the ones I just changed. Quote Link to comment Share on other sites More sharing options...
shh Posted July 28, 2016 Author Report Share Posted July 28, 2016 Tanks for fast response It works as you said but it´s not very good to have to to do that in a running system. Is it possible to boot the PLC before starting the download ("exit to boot" or "exit to factory boot" on screen) and if yes, what is the difference between these to options. Best regards Quote Link to comment Share on other sites More sharing options...
