vamalgise Posted July 29, 2016 Report Share Posted July 29, 2016 Hello, I have new V570, i uploaded a program with nets to read registers from heat meter, Probably i made some mistake with COM initialization, now i cant download a program or view the PLC in online mode. I have completely no clue how to fix it or reset PLC. Please help me, i cant attach attach my program, because its 20KB bigger than the limit (( Thank you. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted July 29, 2016 Report Share Posted July 29, 2016 Hello, If you put the controller into "STOP MODE", you should be able to program a new application into the unit. -Detach power from the PLC -Press and hold your finger on the screen -Apply power while your finger is still on the screen -Once the unit is powered on, tap once on the screen -After the 10 second time-out, it should enter STOP MODE -Establish communications with VisiLogic (remember, default baud is 115200) -Once comms are established, program unit with new application Please let me know if this helps. Quote Link to comment Share on other sites More sharing options...
vamalgise Posted August 4, 2016 Author Report Share Posted August 4, 2016 Hello, If you put the controller into "STOP MODE", you should be able to program a new application into the unit. -Detach power from the PLC -Press and hold your finger on the screen -Apply power while your finger is still on the screen -Once the unit is powered on, tap once on the screen -After the 10 second time-out, it should enter STOP MODE -Establish communications with VisiLogic (remember, default baud is 115200) -Once comms are established, program unit with new application Please let me know if this helps. Thank you very much, it helped! Quote Link to comment Share on other sites More sharing options...
canvj Posted November 8, 2016 Report Share Posted November 8, 2016 I have data tables in my program. Do I need to download the program first and then the data tables to the plc separately? Cheers Vj Quote Link to comment Share on other sites More sharing options...
