wapcs 2 Report post Posted August 1, 2016 I've setup email but i'm receiving the following error: -1 General COM Error. Please check the physical connections. Note: Not sure if it matters but i'm connected via mobile broadband with static IP. Remote connection with VNC and Unilogic is working fine. I've also tried various DNS setups. Optus Mobile Broadband: http://www.optus.com.au/business/support/answer/fixed-mobile-broadband-ip-addresses-email-tech-settings-ports?requestType=NormalRequest&id=1421&typeId=5 Can anyone elaborate on what this error means and how to fix it? Quote Share this post Link to post Share on other sites
Alexander 25 Report post Posted August 5, 2016 Is the Default gateway correct? Can you ping any IP address outside of your network? What type of email client are you using? Gmail more recently set up new security settings that need to be disabled before sending an email from a third party device. Quote Share this post Link to post Share on other sites
wapcs 2 Report post Posted August 8, 2016 The default gateway is the Routers IP address.. 192.168.1.1 I'm using a Custom email account (See attached) Quote Share this post Link to post Share on other sites
wapcs 2 Report post Posted August 15, 2016 With the help of Tech support we resolved this one. We tried a different outgoing mail server and it came good.. Thanks to Eduardo Quote Share this post Link to post Share on other sites
_MELLON_ 1 Report post Posted April 6 i using the Gmail SMTP and receive Error -1 i using correct DNS 8.8.8.8 and i ping it from unistream PLC ,i using correct gateway i use smtp.gmail.com:465 server i also enabled gmail third party connection and check it with my out look can it be that this service was changed or google block it ? Quote Share this post Link to post Share on other sites
_MELLON_ 1 Report post Posted April 9 i found the issue !!! google permit sending 100 email per day and close the SMTP access for 24 hours when pass this restriction if the logic to send email is drive by "Direct Contact" and not "Positive Transition Coil" the logic will send email every PLC loop and block the account immediately ... i think the sending email need to improve with function that will limit sending quotas to prevent the PLC to block the account when logic problem is accrued Quote Share this post Link to post Share on other sites
Liquidcaviar 0 Report post Posted September 7 Hello, Thanks guys, this thread helped me a lot. I have had the similar problem but in my case, leaving the "From E-mail Address" field empty and entering the actual e-mail address in the "Username" Field and activating gmails 3rd party apps access did the trick. Quote Share this post Link to post Share on other sites
Hans Mills 0 Report post Posted November 12 I have the same -1 error. I can ping an outside ip address. I have tried sending through a gmail account with the "Access for less secure apps" set and with the "From E-mail Address" field being empty.I also tried using a Custom Account with the same -1 results. Any ideas? Quote Share this post Link to post Share on other sites
Hans Mills 0 Report post Posted November 18 Tech support helped me. When sending emails, a DNS Server must be included in the Panel Ethernet settings. Add 8.8.8.8 (Google's). Quote Share this post Link to post Share on other sites
