Isakovic Posted August 3, 2016 Report Share Posted August 3, 2016 Is there any way to see which Ethernet socket is active on V700? I went with V700 because it has integrated Ethernet port, but now I can't use SB 147-150 like on other models that require expansion card. Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 3, 2016 Report Share Posted August 3, 2016 Hi, The V700 comprises a special Ethernet card that offers 8 sockets. Note that your V700 applications implement Ethernet differently from applications using other Vision controllers. Please review help topic in VisiLogic - Vision700 - Using Ethernet. It includes explanation how to use the V700 Ethernet statuses. You can find also example for V700 Ethernet under VisiLogic help menu --> examples. 1 Quote Link to comment Share on other sites More sharing options...
Isakovic Posted August 3, 2016 Author Report Share Posted August 3, 2016 Thanks for assistance, It works now. If anyone else needs it, if you use ladder comm function "V700: Read Socket Status", and compare it with 23 it's the same as SB 147-150. Just out of curiosity, do I still need CARD INIT and SOCK INIT blocks for V700 to work? I can't test it easily because I use Ethernet to communicate with it from a distance. Quote Link to comment Share on other sites More sharing options...
tsiz Posted April 27, 2017 Report Share Posted April 27, 2017 On 8/3/2016 at 11:05 AM, Ofir said: Quote The V700 comprises a special Ethernet card that offers 8 sockets. Note that your V700 applications implement Ethernet differently from applications using other Vision controllers. Please review help topic in VisiLogic - Vision700 - Using Ethernet. It includes explanation how to use the V700 Ethernet statuses. You can find also example for V700 Ethernet under VisiLogic help menu --> examples. Hi I also met with the problem Modbus TCP communication V700 I did not find any information Ofir indicated (VisiLogic - Vision700 - Using Ethernet ) on the Unitronics website . Could anybody give a link to this document Thank you in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 27, 2017 MVP 2023 Report Share Posted April 27, 2017 2 minutes ago, tsiz said: I did not find any information Ofir indicated (VisiLogic - Vision700 - Using Ethernet ) on the Unitronics website . Could anybody give a link to this document Ofir was referring to the Help function in VisiLogic, not the Unitronics website. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 27, 2017 Report Share Posted April 27, 2017 On 8/3/2016 at 0:16 PM, Isakovic said: Thanks for assistance, It works now. If anyone else needs it, if you use ladder comm function "V700: Read Socket Status", and compare it with 23 it's the same as SB 147-150. Just out of curiosity, do I still need CARD INIT and SOCK INIT blocks for V700 to work? I can't test it easily because I use Ethernet to communicate with it from a distance. Yes, you have to init Ethernet card. It is recommended make init for all 8 sockets to default settings. Change only what you use. See Help for details. Search for "V700" in Help. This helps to eliminate most of problems with sockets. Quote Link to comment Share on other sites More sharing options...
tsiz Posted April 29, 2017 Report Share Posted April 29, 2017 Thanks guys. I found this Help Quote Link to comment Share on other sites More sharing options...
