MVP 2023 Joe Tauser Posted August 5, 2016 MVP 2023 Report Share Posted August 5, 2016 I am able to connect to a remote V350 on a cellular modem with the PC version of Remote Operator. I put the same settings on the Android version and I get a connection error. I am also able to see the remote PLC in Visilogic. What is the network ID field for on the Android version? Joe T. Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 7, 2016 Report Share Posted August 7, 2016 The network ID should be 0 (You also have it in Visilogic: Unit ID). I'm guessing that an error is causing the android remote operator to assume that there is a connection error. Does the android version able to connect to that PLC without a cellular modem? Have you tried increasing the timeout? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 7, 2016 Author MVP 2023 Report Share Posted August 7, 2016 We tried it on a different phone and it works fine. I need to dig further into the settings on my phone. Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 10, 2016 MVP 2023 Report Share Posted August 10, 2016 Hi all, is there a minimum phone's screen size needed? Once my settings are input, checking says that the connection is ok, hand is green, I can get PLC System Info fine, but it refuses to connect for the main bit. I have only been trying this on my baby screen size phone at present, hence the question. Will try on my bigger one later. When I say "baby", it really is, due to bigger phones getting awkward in my often really cramped work environments. Screen is only 432 x 240. But it runs other things like remote videos etc. perfectly. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 10, 2016 MVP 2023 Report Share Posted August 10, 2016 No go on the bigger phone either. 480 x 854 screen, Android 4.4.4. Exactly the same operations, where everything connects, except the link from the green hand. I have been trying both SIM data and wifi on both phones. I have been trying adjusting length of timeouts and retries etc and have noticed something curious. The "Connection to PLC failed" message seems to pop up after about 2 seconds, regardless of the number of timeouts or their length. I've now also tried it on a FullHD tablet, and exactly the same thing. And an edit in response to Gabriel's post below....all my tries are for a remote system....will try a same LAN situation when I can and advise results. Suggestions please! cheers, Aus Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted August 10, 2016 Report Share Posted August 10, 2016 I have same situation. I can connect phone to PLC when both are connected to same LAN but not remotely exactly as Aus stated. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 11, 2016 MVP 2023 Report Share Posted August 11, 2016 So.....I set up a local 130 to try, and I get exactly the same thing happening. I can get info, it shows the hand as green, but access via the hand then shows the connection failed message. Everything else works fine...but not quite the same result as Gabriel. Tried on all the android devices. Some gliche on getting all the info. I again note that there is not a delay in the message coming up that relates to timeouts and retries. It comes up within 2-3 seconds every time. All my Androids are on Avast, and I get the same result with it on or off. Suggestions please! cheers, Aus Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted August 22, 2016 Report Share Posted August 22, 2016 Hi, Just to clarify this issue, with this mobile app you can remote access Vision Color and Samba controllers. V130 in not supported. We wish to make few tests. Can one of you tell us on which Android version it fails to connect the PLC? Does it failed with any application? Even a blank project? (with just Ethernet setup) Do you have any specific project that we can test on? Please advise. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 22, 2016 MVP 2023 Report Share Posted August 22, 2016 Ahhhh. Thankyou Mr Mozes. I have only been trying to reach 130s. I have up till now not even read the quickstart pdf as the installation was all straightforward. I've just now had a read and it is plainly there for me to see in the list of controllers that a 130 is not supported. If only I had read it initially, but because the app is so simple I saw no need. 1). I politely request that the site statement that it is available for the Vision and Samba series be modified somewhat to say that it does not work with some models. 2). It is frustrating that I have spent a fair bit of time on this. The connection was always checked as valid by the inbuilt testing, but because it is a 130 it won't reach the final step. Yet nowhere in the app is a warning that a PLC type is not supported, if a connection is made to one. There should be. 3). If the app changes in the future to allow more models to connect, please let us all know. Thanks, and cheers, Aus Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 22, 2016 Report Share Posted August 22, 2016 I forgot that the app doesn't support V130 I do agree that there should be a message like: "Unsupported PLC Model" Quote Link to comment Share on other sites More sharing options...
Jan N Posted September 14, 2016 Report Share Posted September 14, 2016 Hi I've tried to connect the app to two different V1040. Connection was unsuccessful. I have Android 6.0.1, which shouldn't be a problem. For me it was strange, that in the app there is no target port entry, as the PC version does. Is there some kind of default target port set, that can not be changed? Any ideas? Jan Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 14, 2016 Report Share Posted September 14, 2016 The port can be changed. You configure it in the same UI where you configure the IP, and PLC name. Quote Link to comment Share on other sites More sharing options...
Jan N Posted September 14, 2016 Report Share Posted September 14, 2016 Ok Sorry! I messed two things up. Net ID and TCP port. Now it works like a charm! Really nice app! Jan Quote Link to comment Share on other sites More sharing options...
alexmoskos Posted October 5, 2016 Report Share Posted October 5, 2016 Something very curious I have come across is that all connections to my V1210 PLC work when I am on the LAN. Remote Operator, Android Remote Operator App, Visilogic. When I am on a different LAN, all applications work well which means I have all Port Forwarding and network setup correctly. What is interesting is that when I use a 3G (on my phone) or 4G (on a different phone) network, the Android Remote Operator App can not connect to the PLC. It attempts to connect, and the PLC actually sees there is a connection established but then the Android Remote Operator App connection never goes through on the phone. Is there some kind of bandwith or "stable connection" criteria? I thought it would have something to do with the size of the graphics cache file or something but I am reaching my limits of knowledge in this area. When I use a separate 3rd Party App (Uni Go), all connections can be made but there are not graphics in that connections, strictly reading of specific MIs and what not. Any ideas why the Android Remote Operator App wouldn't work over 3G or 4G but does work from a different LAN? 1 Quote Link to comment Share on other sites More sharing options...
