MVP 2023 Joe Tauser Posted August 9, 2016 MVP 2023 Report Share Posted August 9, 2016 It would be super awesome if there was a graphic display element that allowed direct display of numbers and strings on the screen. I spend a lot of time coding reading data from tables into MI's just to display the values. With the introduction of the larger displays (V700, V1040, V1210) there is a tendency to display large amounts of collected data. We could specify the Data Table and then use an MI or constant to pick the row and the column. Joe T. 2 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 9, 2016 MVP 2023 Report Share Posted August 9, 2016 +1 There is something similar in UniLogic, but the ability to format the output on the screen is minimal (actually nonexistent). Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted August 9, 2016 Report Share Posted August 9, 2016 +1 I also would add edit data and sort option by desired column. Very useful when using recipes and data logging. 1 Quote Link to comment Share on other sites More sharing options...
HigHTech Posted August 25, 2016 Report Share Posted August 25, 2016 I requested something similar but more flexible. In other HMI software you have a tool for array. You enter the number of rows and columns, spaces between variables. That save a lot of time. Quote Link to comment Share on other sites More sharing options...
