Chive Posted February 6, 2011 Report Share Posted February 6, 2011 I have problem with command "Write SD delimited line". If i compile program i have a error 65 - busy bit missing. Where is problem? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 6, 2011 MVP 2023 Report Share Posted February 6, 2011 The program is looking for a NC of SB 344 in front of the write block so you don't try to write to the SD while it's busy. Joe T. Quote Link to comment Share on other sites More sharing options...
Chive Posted March 22, 2011 Author Report Share Posted March 22, 2011 Thanks. Working fine. Quote Link to comment Share on other sites More sharing options...
