gruku Posted September 6, 2016 Report Share Posted September 6, 2016 Hello I have a problem running the web server on the SD card. Example of the V350 (Webserver with DT) does not work as it is otherwise called network card in the V700. Is it possible to read pages htm. the SD card ?. Regards Quote Link to comment Share on other sites More sharing options...
