Alfonso Xavier Marcial Esc Posted September 17, 2016 Report Share Posted September 17, 2016 Hello everyone! I'm actually studying Automation and I have to make some practices with the Vision 130 RA22. Recently, I have downloaded many manuals about software and specification but I have not found anything related for operating the keypad and I have a problem my former classmates had configurated the Vision 130 to use it with a RS485 and I have a RS232. how can I reset or configurate my PLC to use it again with RS232? this is my e-mail: alfonsoxme90@gmail.com I'd really appreciate your help... Quote Link to comment Share on other sites More sharing options...
Kikis Posted September 18, 2016 Report Share Posted September 18, 2016 Hello, There is a com port initialization function block in Visilogic where you can set all details related to the selected port. Use this function block at the beginning of your program with direct contact of SB2 (Power-up pulse) as a condition for the command to be executed (attached photo). Unitronics help page for Com Init: http://www.unitronics.com/knowledgebase/visilogic/knowledgebase/visilogic/Ladder/Functions/Communications-Ladder_Functions/Com_Init.htm Quote Link to comment Share on other sites More sharing options...
John_R Posted September 19, 2016 Report Share Posted September 19, 2016 AND....... There is a pair of jumpers under the back cover that changes the port from 232 to 485.... Go to the Tech Library and look up the Install Guide for the V130, it shows the proper jumper settings..... JohnR Quote Link to comment Share on other sites More sharing options...
