ORSO2001 Posted September 19, 2016 Report Share Posted September 19, 2016 Dear All, I update at the version 1.18.37 without any problem; I created a new program and I see that if I expand in full screen (F11) I can't select the tag for the HMI object; if I let the screen in "normal size" it works; what can be wrong? to be clear...the tags list appears but if I try to select one of it I don't select it but a row int the "properties window" of the same object. ladder works in both condition. I opened some project done with the version 1.17.73...and for all I saw that some local tags was highlighted as "this tag can be link..."; the local tags was BUFFER. Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 20, 2016 Report Share Posted September 20, 2016 Please send me the project with the buffer. The tag is probably forbidden from being used as a local tag, but I can check it better with the project. You are right about the problem with the Properties Window. I'll open a bug on this issue. We have totally replaced the property grid and the docking (you can now dock-out panes from UniLogic), so there still might be small issues. Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 20, 2016 Report Share Posted September 20, 2016 OK, I have fixed this issue and passed it to the QA. If it works correctly, then it will be a part of UniLogic 1.18 SP release. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 20, 2016 Author Report Share Posted September 20, 2016 Dear Saragni, ok, how can I send you the project? the project was done with 1.17.73 Maybe I found another issue; in my project is present a "PDF viewer"; if I compile the project but the file is missing in the MEDIA folder the "recover alarm" window appear and the unilogic closes; if the file is present in the folder it works. in the version 1.17.73 I have a warning that the file is missing but the copile procedure is done without problem. Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 20, 2016 Report Share Posted September 20, 2016 try sending the project to ---------------- (email address removed) Tell me when you sent it (because if I don't get it, then it got blocked by the IT). Btw, when UniLogic crashes, can you please send the crash report? 10x Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 20, 2016 Author Report Share Posted September 20, 2016 Dear Saragani, I sent a mail. thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 20, 2016 Report Share Posted September 20, 2016 Hi, As i thought, the buffer is being used in the COM Tx element. COM is an IO, and sending data with COM is not immediate. This is why the send is being performed in a different thread (else, it would affect the scan time of the ladder). When you define something as Local, then it is being allocated on the stack, meaning that once the function ends, the data is left on the stack, and might get overwritten when another function is being called, and junk data might be sent. I can't reproduce the missing media problem. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 20, 2016 Author Report Share Posted September 20, 2016 Dear Saragni, ok I understood. About the issue with the missing media file...as I wrote when it happens, before the crash of the unilogic, the "recovery alarm window" appear...if you want I do the procedure and send the report...let me know. thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 20, 2016 Report Share Posted September 20, 2016 Yes, send me the crash report. I might help me to identify the problem. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 20, 2016 Author Report Share Posted September 20, 2016 Dear Saragani, see below for problem detail; however I sent the report as in the procedure: <<System.InvalidOperationException>> from <<System.Xml>> There was an error reflecting property 'HMIElements'. -------------------------- { "ClassName": "System.InvalidOperationException", "Message": "There was an error reflecting type 'Unitronics.PropertiesThemes.SerializableProfile'.", "Data": { "System.Object": null }, "InnerException": { "ClassName": "System.InvalidOperationException", "Message": "There was an error reflecting property 'HMIElements'.", "Data": null, "InnerException": { "ClassName": "System.InvalidOperationException", "Message": "There was an error reflecting type 'Unitronics.PropertiesThemes.HMIElement'.", "Data": null, "InnerException": { "ClassName": "System.InvalidOperationException", "Message": "There was an error reflecting type 'Unitronics.PropertiesThemes.Utils.SerializableDate'.", "Data": null, "InnerException": { "ClassName": "System.InvalidOperationException", "Message": "Unitronics.HMI.Globals.HMIUtils cannot be serialized. Static types cannot be used as parameters or return types.", "Data": null, "InnerException": null, "HelpURL": null, "StackTraceString": " at System.Xml.Serialization.TypeDesc.CheckSupported()\r\n at System.Xml.Serialization.TypeScope.GetTypeDesc(Type type, MemberInfo source, Boolean directReference, Boolean throwOnError)\r\n at System.Xml.Serialization.TypeScope.ImportTypeDesc(Type type, MemberInfo memberInfo, Boolean directReference)\r\n at System.Xml.Serialization.TypeScope.GetTypeDesc(Type type, MemberInfo source, Boolean directReference, Boolean throwOnError)\r\n at System.Xml.Serialization.StructModel.GetPropertyModel(PropertyInfo propertyInfo)\r\n at System.Xml.Serialization.StructModel.GetFieldModel(MemberInfo memberInfo)\r\n at System.Xml.Serialization.XmlReflectionImporter.InitializeStructMembers(StructMapping mapping, StructModel model, Boolean openModel, String typeName, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportStructLikeMapping(StructModel model, String ns, Boolean openModel, XmlAttributes a, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(TypeModel model, String ns, ImportContext context, String dataType, XmlAttributes a, Boolean repeats, Boolean openModel, RecursionLimiter limiter)", "RemoteStackTraceString": null, "RemoteStackIndex": 0, "ExceptionMethod": "8\nCheckSupported\nSystem.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Xml.Serialization.TypeDesc\nVoid CheckSupported()", "HResult": -2146233079, "Source": "System.Xml", "WatsonBuckets": null }, "HelpURL": null, "StackTraceString": " at System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(TypeModel model, String ns, ImportContext context, String dataType, XmlAttributes a, Boolean repeats, Boolean openModel, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.IncludeType(Type type, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.IncludeTypes(ICustomAttributeProvider provider, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.InitializeStructMembers(StructMapping mapping, StructModel model, Boolean openModel, String typeName, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportStructLikeMapping(StructModel model, String ns, Boolean openModel, XmlAttributes a, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.InitializeStructMembers(StructMapping mapping, StructModel model, Boolean openModel, String typeName, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportStructLikeMapping(StructModel model, String ns, Boolean openModel, XmlAttributes a, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(TypeModel model, String ns, ImportContext context, String dataType, XmlAttributes a, Boolean repeats, Boolean openModel, RecursionLimiter limiter)", "RemoteStackTraceString": null, "RemoteStackIndex": 0, "ExceptionMethod": "8\nImportTypeMapping\nSystem.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Xml.Serialization.XmlReflectionImporter\nSystem.Xml.Serialization.TypeMapping ImportTypeMapping(System.Xml.Serialization.TypeModel, System.String, ImportContext, System.String, System.Xml.Serialization.XmlAttributes, Boolean, Boolean, System.Xml.Serialization.RecursionLimiter)", "HResult": -2146233079, "Source": "System.Xml", "WatsonBuckets": null }, "HelpURL": null, "StackTraceString": " at System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(TypeModel model, String ns, ImportContext context, String dataType, XmlAttributes a, Boolean repeats, Boolean openModel, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.CreateArrayElementsFromAttributes(ArrayMapping arrayMapping, XmlArrayItemAttributes attributes, Type arrayElementType, String arrayElementNs, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportArrayLikeMapping(ArrayModel model, String ns, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportAccessorMapping(MemberMapping accessor, FieldModel model, XmlAttributes a, String ns, Type choiceIdentifierType, Boolean rpc, Boolean openModel, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportFieldMapping(StructModel parent, FieldModel model, XmlAttributes a, String ns, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.InitializeStructMembers(StructMapping mapping, StructModel model, Boolean openModel, String typeName, RecursionLimiter limiter)", "RemoteStackTraceString": null, "RemoteStackIndex": 0, "ExceptionMethod": "8\nImportTypeMapping\nSystem.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Xml.Serialization.XmlReflectionImporter\nSystem.Xml.Serialization.TypeMapping ImportTypeMapping(System.Xml.Serialization.TypeModel, System.String, ImportContext, System.String, System.Xml.Serialization.XmlAttributes, Boolean, Boolean, System.Xml.Serialization.RecursionLimiter)", "HResult": -2146233079, "Source": "System.Xml", "WatsonBuckets": null }, "HelpURL": null, "StackTraceString": " at System.Xml.Serialization.XmlReflectionImporter.InitializeStructMembers(StructMapping mapping, StructModel model, Boolean openModel, String typeName, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportStructLikeMapping(StructModel model, String ns, Boolean openModel, XmlAttributes a, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(TypeModel model, String ns, ImportContext context, String dataType, XmlAttributes a, Boolean repeats, Boolean openModel, RecursionLimiter limiter)", "RemoteStackTraceString": null, "RemoteStackIndex": 0, "ExceptionMethod": "8\nInitializeStructMembers\nSystem.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Xml.Serialization.XmlReflectionImporter\nBoolean InitializeStructMembers(System.Xml.Serialization.StructMapping, System.Xml.Serialization.StructModel, Boolean, System.String, System.Xml.Serialization.RecursionLimiter)", "HResult": -2146233079, "Source": "System.Xml", "WatsonBuckets": null }, "HelpURL": null, "StackTraceString": " at System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(TypeModel model, String ns, ImportContext context, String dataType, XmlAttributes a, Boolean repeats, Boolean openModel, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportElement(TypeModel model, XmlRootAttribute root, String defaultNamespace, RecursionLimiter limiter)\r\n at System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(Type type, XmlRootAttribute root, String defaultNamespace)\r\n at System.Xml.Serialization.XmlSerializer..ctor(Type type, String defaultNamespace)\r\n at Unitronics.PropertiesThemes.DefaultElementsProperties.SerializeSystemTheme(SerializableProfile prof)\r\n at Unitronics.PropertiesThemes.DefaultElementsProperties.createSystemDefaultPropertiesXmlIfNotExist()\r\n at Unitronics.PropertiesThemes.DefaultElementsProperties.Init(String fileName)\r\n at Unitronics.PropertiesThemes.DefaultElementsProperties.get_Instance()\r\n at Unitronics.HMI.ScreenBase..ctor(HMIScreenBase screenPoco, IHMIMain mainParent)\r\n at Unitronics.HMI.Screen..ctor(HMIScreen screenPoco, IHMIMain mainParent)\r\n at Unitronics.HMI.Screen.LoadFromDB(Main main, Guid screenId, Boolean initHmiCache)\r\n at Unitronics.HMI.UI.ViewModels.MainViewModel.<>c__DisplayClass3e.<Compile>b__29()\r\n at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)\r\n at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)", "RemoteStackTraceString": null, "RemoteStackIndex": 0, "ExceptionMethod": "8\nImportTypeMapping\nSystem.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Xml.Serialization.XmlReflectionImporter\nSystem.Xml.Serialization.TypeMapping ImportTypeMapping(System.Xml.Serialization.TypeModel, System.String, ImportContext, System.String, System.Xml.Serialization.XmlAttributes, Boolean, Boolean, System.Xml.Serialization.RecursionLimiter)", "HResult": -2146233079, "Source": "System.Xml", "WatsonBuckets": null } Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 20, 2016 Report Share Posted September 20, 2016 OK, it is not related to the missing file, but actually to the Themes feature. We are still investigating why it happens (It doesn't reproduce here, and you've also said that it doesn't always happen). Can you please check which version of .Net framework you have? Thanks. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 20, 2016 Author Report Share Posted September 20, 2016 I have 2 PC...in one, where for sure I have the problem, I have NET framework 4 ....in the second i don't know....I will check later. Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 20, 2016 Report Share Posted September 20, 2016 So no .Net 4.5, 4.51, 4.52 or 4.6/4.6.1? Edit: I've been able to reproduce the problem on a Windows 7 VM with only .Net 4.0 installed. The problem will probably be gone if you update your .net framework (Mine was updated automatically by windows updates). Now, when I can reproduce the problem, then I can write and check a fix for it. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 20, 2016 Author Report Share Posted September 20, 2016 yes sorry, I have Windows 7 with .Net framework 4.0 Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 20, 2016 Author Report Share Posted September 20, 2016 Dear Saragani, I updated the .NET framework at 4.6.1 and the issue is gone. I wait the SP for the version 1.18 to fix the HMI tag problem in full size screen. Thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 20, 2016 Report Share Posted September 20, 2016 Thanks for the info. Anyway, I've fixed that issue, so all people who still have .Net 4.0 (including XP users who cannot update the .Net framework) will have it working. If it passes the QA, then it will be a part of the SP. Quote Link to comment Share on other sites More sharing options...
