kiatar Posted September 26, 2016 Report Share Posted September 26, 2016 I am using JAZZ JZ10-R16 connected with T35 modem. OK , change JZ10 with JZ20 . in Ladder change only Hardware modifier. After power on : SI 180 =2 All funktion is OK onli not initialize modem. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 26, 2017 Report Share Posted March 26, 2017 Hi kiatar, Does SB 185 active when SI 180=2? What are COM port parameters from Info mode? B.R. Quote Link to comment Share on other sites More sharing options...
