Nicos Posted October 3, 2016 Report Share Posted October 3, 2016 Hello, After Windows10 update, I am trying to open Visilogic but I get the following error and the software does not open: "load 12subscript out of range" Any help on the matter? I tried uninstalling and re-installing, and also tried to repair it but nothing worked. Thank you. Quote Link to comment Share on other sites More sharing options...
Alexander Posted October 4, 2016 Report Share Posted October 4, 2016 I would recommend a full uninstall. If certain folders were not removed during the uninstall/reinstall this could be the reason you are still viewing this error. After performing a Windows uninstall of VisiLogic the following folders must be manually removed: Delete the folder “Unitronics VisiLogic_C” from C:\Program Files\Unitronics Delete the folder “Unitronics” from C:\Program Files\Common Files The new version, or a reinstall then then be performed. Quote Link to comment Share on other sites More sharing options...
