Paul Rylatt Posted February 10, 2011 Report Share Posted February 10, 2011 I have not been able to find this in the documentation. The Ethernet card for the V130; is it full and/or half duplex and what network speeds can it run at? I currently have a test unit at my desk hooked to a gigabit switch and running at 100Mbps. I am figuring that is the speed limit since my companies network is 1000Mbps. Quote Link to comment Share on other sites More sharing options...
Emil Posted February 12, 2011 Report Share Posted February 12, 2011 The Ethernet card supports 10/100 MB/s cards (switch automatically), but not 1000MB/s. The card supports 4 sockets. Each can be set independent to UDP or TCP and operate fully separate fron other sockets. This wsy you can communicate with up to 4 dxevices at a time. Which protocol you want to use? Quote Link to comment Share on other sites More sharing options...
Paul Rylatt Posted February 14, 2011 Author Report Share Posted February 14, 2011 A customer wants to know if the ethernet connection is half or full duplex. I have set the V130 to use MODBUS TCP/IP over Ethernet. This is the only socket I make available to the customer. Quote Link to comment Share on other sites More sharing options...
Emil Posted February 14, 2011 Report Share Posted February 14, 2011 On level of electronics, it's full duplex. Quote Link to comment Share on other sites More sharing options...
