OSUstamm Posted February 10, 2011 Report Share Posted February 10, 2011 One small suggestion for the UniCAN Send Block. (It may happen on other communication blocks). When selecting Destination Start Address MI it brings up the description of the address of the same numbered MI for the sending .vlp program. This seems funny to me because the description of that file from the sending program has nothing to do with the same MI of the receiving program. Also, if there is no description it adds the description of "Destination Start Address" to the sending program. For Example... If sending MI10 from PLCX to MI20 to PLCY. While setting this up in PLCX it would change MI20's description on PLCX to "Destination Start Address". It seems silly to do it that way... Quote Link to comment Share on other sites More sharing options...
Emil Posted February 10, 2011 Report Share Posted February 10, 2011 Can you give some idea how you expect this to be? Quote Link to comment Share on other sites More sharing options...
OSUstamm Posted February 10, 2011 Author Report Share Posted February 10, 2011 Can you give some idea how you expect this to be? I think it should be similar to the "Source Vector: Offset" or "Destination Vector: Offset". Just don't have it change the description. Quote Link to comment Share on other sites More sharing options...
