Onionprint Posted October 28, 2016 Report Share Posted October 28, 2016 Hello, I am planning to buy a V1210-T20-BJ and mount it in a panel door. I want to connect it to 3 x IO-DI16's and 3 x IO-TO16's that will be mounted on a din rail inside the panel. What is the module I should use to connect them and what cable should I use? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 30, 2016 MVP 2023 Report Share Posted October 30, 2016 Use an EX-A2X, which will support up to 7 modules of local I/O. It comes with a 1m cable. Cables are available in other lengths up to 20m. Joe T. Quote Link to comment Share on other sites More sharing options...
