Fantasia83 Posted February 10, 2011 Report Share Posted February 10, 2011 Hye all, I'm in trouble with the decimal separator. I'm using RemoteAccess 9.0.1 on Windows 7. I read some operands Values the export them into excel file. It seems that the MF decimal point disappear. When i open Excel 2007 and import the File previously generated with RemoteAccess, all the decimal separator has disappeared. The only way i founded is to change the separator type on windows Control Pannel as a point instead of a coma (We are in France) This is not convenient, i don't want to change our customers system setting like this one. Maybe i'm wrong but i think remote access don't use comma as decimal separator but as object/cell separator. Is there another way ? or an option in Remote access to use comma as decimal separator ? Thank you Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted February 13, 2011 Report Share Posted February 13, 2011 Hi, This is an issue regarding the Excel settings. In Excel, go to: Control panel > Local settings. At the Local Options tab, click on Customize and change the "." with a ",". Quote Link to comment Share on other sites More sharing options...
Fantasia83 Posted February 15, 2011 Author Report Share Posted February 15, 2011 Thx for reply Stein, 1) Decimal system separator = "," i tried to change the excel separator as "." but nothing changed. Ex : I've got MF10 = 40.7437 and MF11 = 40.42034 before exporting them. After Importing into PLc, values are MF11 = 4.07E5 and MF11 = 4.04E6 ?? 2) Decimal system separator "." and everything is OK ! All decimal values are exported and imported correctly !! Quote Link to comment Share on other sites More sharing options...
