Uri Posted October 31, 2016 Report Share Posted October 31, 2016 Hi I try to communicate with Samba 35j (with configured Ethernet card in ladder) by the Hyperterminal program I copied massege from Java example in this forum tcpHeader[0] = 1; //??? tcpHeader[1] = 0; //??? tcpHeader[2] = 101; //Ascii comm type tcpHeader[3] = 0; tcpHeader[4] = 14; ///01RE0020051F + CRC = 14 tcpHeader[5] = 0; String message = "/01RE0020051F\r"; Finaly i have a massege '101010140/01RE0020051F\r' Hyperterminal conected to PLC in 192.168.1.20 20256 I send the massege and northig heppend. WHY. The same result with another programs like Hercules. Regards Uri Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 2, 2016 Report Share Posted November 2, 2016 Well. you say that your message is '101010140/01RE0020051F\r' the 101010140 at the start looks like a string, while it should be a binary. You can look at the Monitor (inside the Info of the PLC), and see the received message. If you see the TCP Header as string, then it is incorrect. The same thing probably for the \r. I Assume that you send it as 2 characters: '\' and 'r', while it means \r (Cartage return). Hyperterminal send strings, so if you write 101010140, then it will send it as string. Read: https://www.seetron.com/archive/html/ht_tip1.htm You can use (at least from what it says) to send special characters using ALT + numbers, for sending the TCP Header. Quote Link to comment Share on other sites More sharing options...
Uri Posted November 3, 2016 Author Report Share Posted November 3, 2016 Thanks for very useful information about hyperterminal. Quote Link to comment Share on other sites More sharing options...
