Interact Posted November 7, 2016 Report Share Posted November 7, 2016 The documentation on the long integer store function says: " Setting SB82 before a Store function causes the 'A' value to be treated as a 32-bit 'long' value; the long value is then broken up into the 2 16-bit MIs constituting the 'B' value. Resetting SB82 before a Store function causes the 'A' value to be treated as a 2 16-bit values; the values are then stored as a long 32-bit 'B' value. " (see http://www.unitronics.com/KnowledgeBase/U90Ladder/Ladder/Functions/Special_functions/_Long__Integer_functions.htm) I have tried this, but it seems to me that the JAZZ does exactly the opposite. I need to use a Reset to convert a 32-bit value to two 16-bit BCD values. Am I doing something wrong? Or is the documentation at fault? Quote Link to comment Share on other sites More sharing options...
