MVP 2023 Ausman Posted December 5, 2016 MVP 2023 Report Share Posted December 5, 2016 I mainly use Data tables as logging devices. They are quite large, get written daily to the SD and I routinely download them from the SD using Explorer. They then start again for the next 24 hour period. Sometimes I need info before the table is written to the SD, and if I have a few in use, getting instant info about them is a PITA. I access Data Tables directly using Visi. Clicking on each table name highlights that table and brings the last saved into view. The PITA is that when I use Connection/Read Structure and Values from PLC to get the current values, Visi uploads ALL the tables. On a slow connection this is very annoying, and a big waste of time. Can we please have this changed to just have the selected table uploaded? cheers, Aus Quote Link to comment Share on other sites More sharing options...
