greml1n Posted December 16, 2016 Report Share Posted December 16, 2016 Is there any way to change the status of bits in an indexed data table without using the data table editor in uniapps, online mode or the widget. I was hoping I could use the write to column function with 1 or 0 but it doesn't work. Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 19, 2016 Report Share Posted December 19, 2016 Set Column in DTI does work for bits. I've just tested it. Do you have a project where it doesn't work? Quote Link to comment Share on other sites More sharing options...
