adis1001 Posted December 19, 2016 Report Share Posted December 19, 2016 Hi, I have a problem. I have a few variable on display, but they are alignment from right to left. And when VR1 is low there are three empty place. Is there any way to change it? Now I have something like this: M: ####S: ### And when V1 and V2 is big this is look like this: M:2453S:235 But when this small: M: 3S: 2. This is possible change it to: M:3 S:2 ? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 19, 2016 MVP 2023 Report Share Posted December 19, 2016 On the left side, right in the middle of the Numeric Variable setup is a drop-down called "Leading:". There you'll find 3 selections: Leading zeroes. leading spaces, no leading. Try changing to "No Leading" and "Text Alignment" (far right, near the bottom) to "Center Left". Quote Link to comment Share on other sites More sharing options...
